Occasional Contributor I
Mac auth using clearpass
On reloading the LAN switch, some users go into blocking state.On flushing mac address on switch it works fine. May I know whats wrong?
Clearpass access tracker has below messages:
Endpoints Repository] - localhost: User not found.
Static-host-list1011: No free connections available
StaticHostList-1012: No free connections available
StaticHostList-1013: No free connections available
StaticHostList-1014: No free connections available
StaticHostList-1015: No free connections available
StaticHostList-1016: No free connections available
StaticHostList-1017: No free connections available
StaticHostList-1018: No free connections available
StaticHostList-Edge55-56: No free connections available
StaticHostList-AccessAllow: No free connections available
MAC-AUTH: MAC Authentication attempted by unknown client, rejected.
2016-05-25 05:52:22,597
[Th 81385 Req 1696477 SessId R00023561-01-5745a006] ERROR RadiusServer.Radius - rlm_shl: No free sql connections available
[Th 81385 Req 1696477 SessId R00023561-01-5745a006] ERROR RadiusServer.Radius - rlm_sql (auth_local_db): There are no DB handles to use! skipped 0, tried to connect 0
2016-05-25 05:52:22,598
2016-05-25 05:52:22,599
2016-05-25 05:52:22,601
2016-05-25 05:52:22,602
2016-05-25 05:52:22,604
Thanks in advance!!
Re: Mac auth using clearpass
Please open a TAC case so they can investigate.
Thank You,
Troy
