jt-
Macbook not consistently authenticating 802.1x
I'm having an issue with a single macbook using the El Capitan OS. We're using Clearpass 6.4.7 as our AAA server. When I check the client in the Clearpass Access Tracker - Input - Authorization Attributes I don't see all the information for example none of the end point repository information which we use to authenticate the device. We've compared the configuration with other macbooks and it's the same and they work fine. We've done a hardware diagnostic check on it came back fine.
Any Thoughts? Thanks
John
