Machine and User Authentication
Hello Collin
Question regarding this
If i got machine enforment on and also  EAP PEAP to athenticate with user and password
I got it set up like this
When you authenticate with the correct machine you  actually get an ip address but you get a deny all role
When you authenticate the user then you get a derived role which got the real access.
Now as i got it, it will affect the users that needs to change to a new password? i mean when they have a group policy  which tell you, that you need to change the password every X time?
I did it this way because i want that it needed to pass both authentcation before having any access to the network.
But it seems it will give me trouble...
If im correct in what i thing
To correct it what do you recommend?
I was thinking in maybe that when it pass the machine authentication  it give you just the privileged to change the pasword... maybe just opening the ports that its needed for this agains the active directory ip address
Or do you suggest another aproach?
Thanks in advance
Cheers
Carlos
Alternetworks Corp
Frequent Contributor II
Re: Machine and User Authentication
I agree :)
NightShade1 wrote:
Hello Collin
Thanks in advance
Cheers
Carlos
You need to pass machine authentication before you do anything.  Correct.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
