Machine authentication Question
hay.
I'm using NPS as radius server.
i wante to do  the following senario :
groupe one :
machines auth+users auth
groupe two:
users auth.
can i do it with role derivation (it the same ssid) .
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Machine authentication Question
i know how to enforce machine authentication.
but i need to enforce only groupe one to do machine authenication.
the second group will only do a user authentication .
can i do it with NPS  or not (in the same vap)
Raouf CHAHBOUNE
rchahboune,
Neither NPS or the Controller has the logic to enforce machine authentication for specific groups of people.  You would need a Radius Server that supports this, like ClearPass Policy Manager.
