Valued Contributor I
Maping between clearpass and twitter terminology
I'm looking to confgure social media auth for our guest network.In clearpass 6.4 I can select twitter as the social media of choice  and I then have to supply a Client-Id and a Client-Secret.
On Twitter I've created an app with "sign in to Twitter" enabled.  The app has an api-key,api-secret,owner and owner-id.
So which of the twitter app items above do I map to client-id and client-secret in clearpass parlance?
Has anyone got  some step by step instrucuctions for setting up clearpass to auth via common social media sites e.g. facebook,twiter, linkedin? e.g.
Perform these steps on < media site of choice>
Perform these steps on clearpass server
Rgds
Alex
Re: Maping between clearpass and twitter terminology
It should be the API key / secret
Sent from iPhone
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Troy's posts explains pretty well how to configure the service and auth source:
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Social-Media-Tips-2-SQL-auth-sorce/m-p/195459/highlight/true#M14547
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Social-Media-Tips-3-CPPM-Service/m-p/196255/highlight/true#M14615
Thank you
Victor Fabian
o.k. foind that reference in the clearpass hep document ..... but there's nothing called a consumer-key or secret in the twitter app
Rgds
A
Use the
API Key = Client ID
API secret = Client Secret
Thank you
Victor Fabian
