Regular Contributor I
Mass import of guest devices possible?
I have about 60 devices that I want to import, but see no way of doing this other than with guest user accounts.
We have the need to connect certain devices that bypass the portal registration pages, and just use their mac to connect.  We would notmally do this via the Manage Devices, Create page.. but dont really want to do this for 60 devices.
Is their an easy way to import them all, as I already all of their mac's.
Re: Mass import of guest devices possible?
Add a device manually, then export it to see the expected format. Then use the Import Accounts menu.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
Good idea!
Although having now tried, the import feature seems to only apply to creating guest user accounts, and not guest device accounts, and is asking for a password field, which doesnt exist.
