Micros Fidelio with CPPM
If any of you are using the Micros Fidelio intergration in CPPM can you send me a note?
Thank You,
Troy
Re: Micros Fidelio with CPPM
Good question / request.
Im also interesting about this kind of connectivity between CPPM to micros fiedlo..It will save me the need of using Nomaidx as GW....
im on the same boat....
I hope that it makes it compatible near in the future, in which it fully integrate like the nomadix
Cheers
Carlos
Alternetworks Corp
The full integration is in the 6.3 and engineering has passed on the approval from Micros Fidelio, but we would like to see if anyone has it in production to get the final seal from Micros Fidelio
Thank You,
Troy
That woudl be really nice!
It also would be really nice a video of how to integrate both things :D
Cheers
Carlos
Alternetworks Corp
Video or Step-By-Step PDF will be just gr8 , cant wait for it.
I have couple of sites that using Micros Fiedlo...and those days i must use Nomadix :( And i don't like it .
Hi Guys
Is there an Integration Guide available for Clearpass and Micros Fidelio?
Mike
