Mobile Devices access control
Any one have the idea of restrict the mobile device access? only allowed mobile device can access the WiFi, remaing all shouldn't connect Corporate. wireless users & devices were in same VLAN.
we have the 3200 controller, AP 225 and CPPM 500 device.
Re: Mobile Devices access control
You can use this guide that Tim created as a guideline. But the only way to keep certian devices off a SSID you need to have a list of MAC address or add a tag to each of the allowed devices or a MDM that you can use as a list of allowed device.
Thank You,
