Motorola WiNG 5.x Radius CoA doesn't work
Hi
I'm trying to integrate Motorola Controller WiNG 5.x with Aruba ClearPass OnGuard.
As I have learned this controller support Radius CoA as for example we can see here:
http://wirelesssolutions-blog.blogspot.com/2014/02/wing-radius-attributes.html
I have configured SSID with 802.1x and enabled dynamic vlan feature, that seems works ok, then I have tried to terminate session via Radius CoA. Authentication works ok. SSID in tunneled.
I have enabled Radius Dynamic Authorization option under Advanced of WLAN settings.
I have tried built in Motorola enforcement profile and some other, also send Radius attribues as in above link (1, 31, 44)
But still without success.
Can someone help ? Has anybody similar problem ?
I'm not very fluent on Motorola solution, but already works some time on it
Regrds
Re: Motorola WiNG 5.x Radius CoA doesn't work
What is shown on the CoA tab in access tracker?
Tim Cappalli | Aruba Security
Hi
What do you mean by CoA tab ? sorry but I can't find it.
You mean Radius response under Output TAB ?
regards
Karol
After manually issuing a DM/CoA from access tracker, a CoA tab will appear on the initial request.
ok, thank you
It seems that now it works :)
Your guides led me to solution, but it is not clear for me
One issue:
When I try to make CoA manualy I can do it only for one Enforcement profile (drop down list: Radius CoA Type) although I have couple of it.
When I have changed this profile to work with Motorola (1,31 and 44) and added it to policy, It stareted to work
Why it is so ?
I forget about something ?
regards
Karol
