Multi-controller captive portal SSL certificate
I did a CSR for my master controller and installed the certificate with the name wireless.xxx.yyy.edu. This is the name I would like to use as the URL for the captive portal redirect. How can I export the certificate with private key from the master to add to the local controllers?
Tim Cappalli | Aruba Security
Re: Multi-controller captive portal SSL certificate
You have to generate a CSR for each controller, just like you would for each server in the real world....
So I assume a second certificate with the same DNS name on a different controller wouldn't interfere? We'd like it to be lyndonwireless.xxx.yyy.zzz for all controllers.
Moderator
My advice would be that you NOT generate the CSR on the controller, because we specifically make it very difficult (if not impossible) to get the private key off the controller.  If you want to use the same certificate on multiple controllers, I would suggest following this workflow:
1. Find a Unix box with OpenSSL on it
2. Generate the private key
3. Generate the CSR, using your desired hostname as the CN
4. Get the certificate from the CA
5. Put the certificate and private key back together as a PFX / PKCS#12 file, which will be password protected
6. Load the resulting file on all your controllers
There are lots of resources online to tell you how to do these common OpenSSL operations.  The one I typically refer to is here:  http://www.sslshopper.com/article-most-common-openssl-commands.html.  I'll cut and paste the important bits:
  • Generate a new private key and Certificate Signing Request
    openssl req -out CSR.csr -new -newkey rsa:2048 -nodes -keyout privateKey.key
  • Convert a PEM certificate file and a private key to PKCS#12 (.pfx .p12)
    openssl pkcs12 -export -out certificate.pfx -inkey privateKey.key -in certificate.crt -certfile CACert.crt
Jon Green, ACMX, CISSP
Security Guy
Contributor I
I've tried this and I am receiving an error when trying to upload the cert in the controller. Its telling me that it is an invalid format.
Is this correct? (-in certificate.crt = server cert received from CA. -certfile CACert.crt = root cert)
Thanks in advance.
I am gettign this same error.
Anyone have an update?
Please contact support if you need to get this done sooner, rather than later..
Contributor I
Support was very helpful with this resolution.  Once you get the cert from the CA don't do the last step.  Get the intermediate and merge them together putting the intermediate above the server cert in the same file.
Similar to this:
-----BEGIN PRIVATE KEY-----
MIIEvgIBADANBgkqhkiG9w0BAQEFAASCBKgwggSkAgEAAoIBAQC3bNP/cwKFtPzp
8POlTne123asSgV4tn97zzScVoyhrEsPz7SggL3B40RFb/sMsGbJnDIYer+ZuzxV
-----END PRIVATE KEY-----
-----BEGIN CERTIFICATE-----
MIIFJTCCBA2gAwIBAgIETB2bFzANBgkqhkiG9w0BAQUFADCBsTELMAkGA1UE
BhMCVVMxFjAUBgNVBAoTDUVudHJ1c3QsIEluYy4xOTA3BgNVBAsTMHd3dy5l
-----END CERTIFICATE-----
Save the file and you should be able to upload it without any issues.  Worked for me and now have this same cert on 3 controllers and adding it to more.
Anyone know how to export and decrypt the private key?
I'm unable to use Green's adviced solution as I have to generate the CSR on the Aruba RAP itself, and need to store the Certificates on USB Flash Drives.
Would appreciate if someone with the knowledge could share the steps needed to get this done.
There are a lot of third party websites that you can use to do the csr. As Jon stated it is not easy to decrypt the pkey.
Thank You,
Troy
