Regular Contributor I
NAC with 2520 switch
Hi All,
    I am trying to setup port security between Clearpass and a 2520 device. I believe everything is setup OK but there is nothing showing in access tracker or venet viewer. This is a brand new CPPM and I've setup this on the switch -
radius-server host 10.x.x.x key "secretkey"
radius-server host 10.x.x.x dyn-authorization
aaa accounting update periodic 3
aaa accounting system start-stop radius
aaa authentication port-access eap-radius
aaa port-access authenticator 2
aaa port-access authenticator 2 client-limit 3
aaa port-access authenticator active
aaa port-access mac-based 2
aaa port-access mac-based 2 addr-limit 3
But the show port-access authenticator clients command just shows the client status as "connecting"
The CPPM is pingable from the switch and vice-versa.
Any ideas
Re: NAC with 2520 switch
OK so it looks like the requests are arriving at another configured server. Is there any way to point the requests to CPPM on a per-port basis? or some other workaround.
Regular Contributor II
Please check the event viewer if you have an error in the shared secret or if the NAD is not configured in CPPM. As this is a new installation you might have missed something.
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
