Frequent Contributor I
Nagios plugins to monitor physical clearpass appliances
Hey all,
I'm just starting to set up my first batch of cppm appliances, and I'd like to get them properly monitored. Does anyone have any good nagios plugins for monitoring them?
Re: Nagios plugins to monitor physical clearpass appliances
Hi Team,
Can find the below information with regards to this thread.
http://udel.edu/~doke/nagios/check_clearpass
Good day.
Hi!
Is this a the correct link?
Please can you post the correct link?
Thank you in advance!
This is the answer we get when we click on the link:
The page you requested was not found on this server.
You may have found an outdated or mispelled link, or you made a typing error. If you followed an incorrect link, you may wish to inform the administrator of the referring page.
@ Nithiy,
Yes, if we click on the URL it navigates to http://udel.edu/~doke/nagios/check_clearpass and results in the below:
However, if you copy this URL in next tab, and hit enter, it will work as below:
