Need Tips
I just bought Aruba IAP-135. I create Guest SSID (open network, no password) but use splash page from aruba to authenticate user.
Is my setting secure ? or any good practice for setting guest network ? (Note without clearpass)
MVP
Re: Need Tips
[ Edited ]
Well for guest you can use as  you said the captive portal... if you use the internal database.
When you making the guest wireless you can try this:
1-In the role you using after the captive portal authentication put a role in which it just have access to the internet and it does not have access to anything in the internal network, you can do that with the roles.
2-Try Natting so the network you using does not exist in your internal network, let say 172.16.3.0/24 let say that network does not exist in your network, well then use that one and nat through the IP of the AP i don tknow if you get the idea?
3-You can periodically change the password of guest... as it does not automatically expire like with the controller..... I asled for this feature, you can vote for it on the ideas tab, if it get lot of kudos they might put it on future releases.
Alternetworks Corp
MVP
Re: Need Tips
Ah yeah there is a VRD for this of tips for  how to build your guest network i mean how aruba recomends... this is made for the controllers based but you still can fallow some of advice with the Instan APS
Here is the link is not a long reading...
http://www.arubanetworks.com/wp-content/uploads/AOS_GuestAcccess-AppNote.pdf
Hope it helps you
Alternetworks Corp
