Need help on ClearPass cluster setup
Hi, We have ClearPass 5K VM license for 2 nodes for single office premises and would like to setup Cluster but we need recommendations on below configurations.
1. ClearPass cluster setup recommendations and what options we should follow
Option1 - Publisher-Subscriber
Option2 - Publisher-Subscriber-VirtualIP
Option3 - Publisher-Standby Publisher - VirtualIP
We are planning to use Wired/wireless dot1x authentication, Onguard and Guest portal for 50 users.
Can we go for configuring only data interfaces (no management interfaces configured) for 1200 employees/2500 nodes in the network. which option is suitable and please suggest.
Yugandhar.
Re: Need help on ClearPass cluster setup
Option 3 is probably best. You can use the management interfaces only.
Tim Cappalli | Aruba Security
