Frequent Contributor I
Need to Get more detail around Clearpass License Usage
Hi
I was wondering how I can get more information around my Clearpass current license usage.
I have 4 x5k VMs in a cluster giving me 20K Policy Manager Licences - when i log in on the cluster I have a banner indicating my licensing has been exceeded and I have 20862 devices -- however when I go to the licensing page it indicates that my Used count is only at 15597.
I understand how the Licensing gets averaged out over 7 days and so forth -- however I need to check how long it has been exceeded, when the average calculation will be reset, aswell as when will we be affected by the license exceeded behaviour of clearpass.
Any aditional licensing information I can get other than the normal information displayed on the GUI will be great.
THX in advance
Re: Need to Get more detail around Clearpass License Usage
Once you hit the violation mark it will show for the 30 day period until the reset at the end of the month. You might have had a violation the week before and when you are looking at it that day it is after the event happened it will only show for that day.
Thank You,
Troy
