Need to create a custom filter in access tracker
hi Team ,
Need an help , in CPPM ,in access tracker coloumn ,could see many default filter such as request ID , source ,etc i need to create a custom filter with named framed IP address ,which is one if the attribute ,Please let me know your inputs. Thanks in advance
Re: Need to create a custom filter in access tracker
You cannot add custom columns.
Tim Cappalli | Aruba Security TME
Thanks for your reply ..actually i need to identify the guest user we have 172.x range subnet defined for guest range ,i could see defalut only server IP i.e controller IP alone ,i need to identify the exact user where IP starts with 172.x range........
You could create a custom data filter and use that.  Need to have accounting enabled.  See example below.Snip20180108_33.png
And then edit your access tracker view and select that filter.Snip20180108_34.png
ACCP, ACCX #817, ACMP, ACMX #294
