Nested groups in MemberOf for active directory not being followed
I have a group in AD that has a nested group as its members, very usefull when granting application privs.
I wanted to assign this group read only access to ClearPass, but it seems that CP doesn't follow nested groups?
When I looked at the authorization attributes
Authorization:Brandeis Active Directory:memberOf: only shows the primary memberships not the memberships of the nested groups...
Is there a setting I can change to have it show that?
Re: Nested groups in MemberOf for active directory not being followed
Edit:
Attached is a preliminary document on how to configure CPPM for nested groups..
I am also running into this problem.  Any help would be appreciated.
PM Collin and ask for the same doc he sent me.
It was pretty easy to get it working but the doc was needed to wrap your head around reading into nested groups
Frequent Contributor II
I need the document also... hopefully nested groups will be fully supported in a future release.
I just use all of the levels and leaf options for each one so you always catch it.
Tim Cappalli | Aruba Security
Occasional Contributor I
Instead of using the OneLevelUp/Leaf method of searching nested groups is there any reason to not use something like:
(distinguishedName=%{memberOf:1.2.840.113556.1.4.1941:})
for the Groups query?  This seems to return all the nested groups in Active Directory.
The resource I used to find this was: http://msdn.microsoft.com/en-us/library/aa746475%28VS.85%29.aspx
  Eric
Edit: This doesn't actually work, I had the query wrong and was allowing access to all groups.  It does work if you modify the auth query, but then it's very ackward, i.e.:
(&(sAMAccountName=%{Authentication:Username})(objectClass=user)(memberOf:1.2.840.113556.1.4.1941:=CN=NestedGroup...))
If there's a way of retrieving nested memberOf attributes from Active Directory that would be ideal.
MVP
Seems nested groups still do not work 'our of the box'.
Is there any intention to get this config into ClearPass per default?  Is that v2 document still the latest version?
Koen (ACMX #351 | ACDX #547 | ACCP)
I was shared an LDAP OID from support and some basic 'n-1' traversal that can deal with this better than the original pdf shared at the top of this thread.
Is this the new gospel way of dealing with this ?
Are you using generic LDAP or AD?
