Frequent Contributor I
Network monitoring
Hello, I would like to know what you use to do monitoring on your network (PC and SNMP)?
Super Contributor II
Re: Network monitoring
For the Wifi we have Air Wave and and for other devices we have Solar Wind.
Thanks & Regards
Syed Murad Ali
Thank you.
Same here. (AirWave / Solarwinds)
I can also recommend PRTG for network device and system monitoring (VMware, Hyper-V, APC UPS, etc). Their development cycle is very fast and their pricing can't be beat.
Solarwinds can be frustrating and is very expensive.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
PRTG looks very good and also it has what I want.
