Frequent Contributor II
Network switch Tacacs accounting issue on CPPM
We have configured tacacs on Nortel 4550 switch.
If we insert “Tacacs authorization level all” command on switch, We were able to get detail accounting log on CPPM
But same time I got “your command was not authorized”  message on Nortel switch while entering any command.
Please find attachment for configuration and accounting log
Thank you..
Re: Network switch Tacacs accounting issue on CPPM
Are you trying to set up TACACS+ accounting or command authorization?
Tim Cappalli | Aruba Security
I want to know which command has used by user on network switches.
Using tacacs or radius.
Please post your switch config.
Switch configuration is same as below
On the commands tab, check "Enable to permit unmatched commands".
Hi Cappali,
Could you please share commands which are used in Enforcement profile for Tacacs+
Thank you
As previously mentioned, all you need is:
