Not able to get framed-ip-address while doing 802.1x and mac auth
We are doing 802.1x and mac authentication on wired network and it working fine also but in accounting tab am not getting framed-ip-address. Can anyone help me please.
Re: Not able to get framed-ip-address while doing 802.1x and mac auth
In AAA typically the NAS (authenticator) is typically not aware of the Framed-ip-address to pass it on to the radius server when using 802.1x or mac auth.  Only in Captive Portal authentication is the NAS guaranteed to know the Framed-ip-address.
Moderator
So CPPM gets the framed-IP-address from the radius-accountign data, please ensure you have enabled radius-accounting/interim-accounting on your NAS. Some NAS's only get the IP address after the authN is done so its important to have interim enabled.... this is very NAS dependent.
Best Regards
-d
ClearPass Product Manager
