Not able to send Radius CoA or disconnect message from Clear Pass.
I am testing a solution with Clearpass with Juniper EX switches.
I am not able to generate Radius CoA or Disconnect message. When I explore Access Tracker and click on change status I see Radius CoA option disabled and I can't enable it.
If anybody has working solution or configuration steps; please share.
Regards
-Rajeev
Re: Not able to send Radius CoA or disconnect message from Clear Pass.
Do you have CoA enabled in the NAD configuration?
Tim Cappalli | Aruba Security
Please update us with your problem.
I had the same problem and it was revealed to be that the Juniper EX2200C-poe needed a software upgrade.
