Notification of Expired Authentication through ClearPass
We have users that are authenticated for 90-days through ClearPass. We are starting to hear rumblings of complaints that other than the little explanation point in the system tray, they have no idea they are not connected to the network after the 90-day period. They are wanting a pop-up notification that their connection is about to expire, much in like the way A/D starts warning you that your password is about to expire. Do you know of a way to do this in either ClearPass or an App that can monitor this that would run locally on the laptop?
Re: Notification of Expired Authentication through ClearPass
Unfortunately there is not. However, the Onboard feature does allow for an email notification X days before their certificate expires.
Tim Cappalli | Aruba Security
Perfect... That's what i needed to know. Thanks.
