Frequent Contributor I
Object definition not found: 485930562960345200
I'm currently running 3.9.9 of Guest Manager, and have created a guest self-registration object using a not-descript registration page. However, since moving focus away from this self-registration object, e.g. navigating to another menu, I'm no longer able to edit any information due to the "Object definition not found" error.
Has anyone come across this before or able to test in their environment? The self-registration page is hosted at 485930562960345200.php.
Any amount of Kudos will be greatly appreciated!!!
Re: Object definition not found: 485930562960345200
That is a verbose not found error.  Can you confirm in the Self-Registration list you see your item without issue?  Can you load the registration page (versus the edit area)?
I used your page value and had no issues.
