Frequent Contributor II
OnBoard - Two Certs to choose from
I am working through Dual SSID onboard. When the QuickConnect application installs the EAP-TLS wireless network on my Windows 10 machine, I am prompted to pick a Certificate. Why are two certificates being offered and how do I get rid of one of them? I would like for this to be as seemless as possible. Avoiding the certificate selection is prefered.
The first Cert shows just my user name. The second cert shows username@domain.com
This is Windows 10. Thanks for the help!
Re: OnBoard - Two Certs to choose from
You need to import the trust chain. One is the server cert and one is the device cert. You need both
Thank You,
Troy
Sorry missed your screen shot. U can remove the old one in certmanger
Thank You,
Troy
That is what I was thinking too but I cannot find a cert that matches these in Cert Manager.
