Hello!
Clearpass 6.4
Aruba Controller 3200 - 6.1.3.4-AirGroup
iPad 2 - IOS 7.0.2
Scenario: OnBoarding using 2 SSID - one Open Guest, one closed EAP-TLS
OnBoarders can be either self-registered guests or AD users.
To the issues
1. Unable to auto-switch to EAP-TLS network after provisioning.
I'm unable to get the auto-switch to closed network to work. correct switchip and mac is in the redirect URL. I've tried removing ALL other networks on the iPad. Changing the onboard settings to a manual click to switch..
No luck! Neither at Customer site nor in my lab.
Should this be working? And if so - what the heck are you running and what kind of config makes this possible?
2. Safari hangs during provisioing-login
Customer complains that Safari just hangs and not doing anything when their AD users input their AD credentials in the onboard provisioning page using their iPad. I can replicate it so it happens alot. I can even type in wrong password and nothing further happens. If I try to trigger a new redirect while Safari is "busy" - I just get a page can't be located error message.
Note that in this scenario there is NO messages in the Access Tracker that I'm even trying to log in. So it seems that Safari just halts any traffic.
I then kill Safari, re-open and trigger a new redirect. This time login is succesfull and I run through the provisioning process without any problem.
This sound familiar to anyone? **bleep** annoying ... Especially since I can't use any other browser than Safari to actually do the provisioning..
