Regular Contributor I
OnBoard with Posture
I have OnBoard configured with Pre-Auth using Active Directory. Is it possible to configure a dissolvable posture check before/during the Onboarding process?
I can create a Self-Reg page for OnBaord and Posture check but that wont allow for AD auth.
Weblogin with AD auth and link to Onboard doesnt allow for Posture check.
I think the answer is no.
Re: OnBoard with Posture
They would be separate flows. Check posture, if healthy, return Onboard enrollment role.
Tim Cappalli | Aruba Security
Ahh.. yes! So many options sometimes obscures the easy ones. Thanks as always Tim! I sit ACCX in two weeks and am just anticipating such scenarios.
