Regular Contributor II
OnBoarding with Cisco WLC
Hi forum,
I'm trying to this to work but no luck so far.
I followed the ase solution but my clients are able to access the Internet and they are not being redirect to the onboard page. I can see in access tracker that CPPM is sending back the correct redirect ACL but the client is getting to the Internet. I attached some screen shots of the ACL on the cisco controller. I followed this pdf CPPM-WLC_integration-v1.1 but still, the user is able to access the internet without getting redirected. I even added a deny all at the bottom of the redirect acl but it did not change anything. oh I also attached my enforcement profile.
Re: OnBoarding with Cisco WLC
You need to return the following:
url-redirect-acl = "ACL NAME"
url-redirect = "URL"
Thank you
Victor Fabian
Lead Mobility Architect @WEI
that's exactley what am returning.... see the attached Screen Shot 2016-12-20 at 2.09.13 PM
You are only returning the ACL, you also need to return the onboarding URL
Thank you
Victor Fabian
I get that. See my enforcement profile attached. it has both but access tracker only shows that it is returning the ACL
Try using this:
url-redirect=https://<clearpass-ip>/guest/onboard.php?mac=%{Connection:Client-Mac-Address-Colon}
Thank you
Victor Fabian
Thank you Victor, that was it.
Glad to see Victor was able to help.  Please don't forget to accept the solution if it worked!   ;)
