OnGuard VPN (EAP-TLS Machine Cert Auth) with Health Checks (no Auth)
Hi All,
Can someone briefly explain to me how this works?
On the ClearPass access tracker VPN authentications always have a posture as unknown, even when the client shows health status as healthy and directly after a successful health check.
Is this happening due to Via clients MAC address showing as 00:00:00:00:00:00 (as per the outstanding bug)??
Cheers
James
Cheers
James
Re: OnGuard VPN (EAP-TLS Machine Cert Auth) with Health Checks (no Auth)
Bump.
I'm not sure what would link the authenticated client to the health check other than the MAC address but as it all zeros... How would this work?
Cheers
James
Sorry for the delay. When using OnGuard with VPN, you need to do Health Checks with Authentication.
Tim Cappalli | Aruba Security
Hi Tim,
Thanks for the reply. I'm authenticating using a TLS machine certificate (no authorization) and doing domain pre-connect. In this scenario if I enabled health check with auth would it work or would I also need to enable authorization on my EAP-TLS authenticaiton method?
Reason for asking is, in my scenario, using health check with authentication would mean CPPM would see 2 authentication requests. 1 would be from the machine for VPN auth and the other from the user for health check auth. Would CPPM know the health check authentication was from the same device as the machine based TLS auth?
Cheers
James
Cheers
James
Just to add a bit more details.
Here's a successful healthy posture.
Immediately (9 seconds later) followed by my Via authentication:
So my posture was healthy, then it was unknown.
I have cached roles and posture enabled.
Cheers
James
FYI this configuration is not supported.
The username in the certificate needs to match the username in the health check so only user certificate will work with health checks with authentication.
Currently machine based certificate don't work with health checking.
Cheers
James
UPDATE: Aruba Engineering are working on a fix for this.
Cheers
James
