Onboard - Sponsorship only for certain device types.
Don't think this is possible, but will ask the question anyway.
Customer want the onboarding process to have a sponsorship approval, but only for Windows devices like laptops.  Other Android and iPhone etc will proceed without the need for approval.
Is it possible?
ACCP, ACCX #817, ACMP, ACMX #294
Re: Onboard - Sponsorship only for certain device types.
I think this would be an RFE. It's all or nothing today.
One workaround would be to use the ClearPass and controller device profiles to assign a different provisioning profile. One that has sponsorship enabled and one without.
Tim
Tim Cappalli | Aruba Security
Yeah, that's exactly what I started thinking after I posted.  It does rely on the device being profiled first though.
We are using a link in the guest page to redirect to the onboard portal.  Could maybe put another link in there that redirects to a different provisioning profile.  That should work.
For stuff like this, I tend to use the Aruba-Device-Type VSA from the RADIUS
request along with the ClearPass profile data.
That's awesome.  I've never used that attribute.
Interestingly, when sponsorship enabled, there is nowhere to put in the sponsor_email in the portal page.
Michael_Clarke,
Which portal page?  sponsor_email is a field that can be added to the page or hardcoded.  It is not something that happens automatically.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
The 'Register you device' page.  I thought that enabling sponsorship would add a place for them to put the sponsor_email.  I can hard code it though which is probably better.
