Onboard - TLS Issues, User not found
Clearpass VA (ESXi) with Onboarding version 6.6.5.93747
so trying to setup onboarding using a single SSID..
I have used the wizard to create the necessary services and policies.
I have then created the necessary networks, CA Server and onboarding profiles.
I have modified the pre-provisioning Enforcement profile to allow me to authenticate to AD for the PEAP portion of the process.
I have then tested this with a windows 10 machine, the peap works fine and i can get to the onboarding page and download the software. I can run the software and get a Certificate installed (under the user's Certificate store) and the computer gets configured to then connect using TLS.
But the TLS Authentication fails with the error message
Error Code: 201
Error Category: Authentication failure
Error Message: User not found
 Alerts for this Request
RADIUS
[Onboard Devices Repository] - localhost: User not found.
[Guest User Repository] - localhost: User not found.
EAP-TLS: Authentication failure, unknown user
I have looked under onboard and the user is registered and the device is registered as well..
What am i missing...
Re: Onboard - TLS Issues, User not found
Make sure your identity store is added as an authentication source.
Also, dual SSID onboarding is recommended in most cases.
Tim Cappalli | Aruba Security
Contributor II
I´ve got this exact issue, did you manage to solve it ?
/Daniel
ACMP | ACCP | HP ATP - FlexNetwork Solutions
Contributor II
Anyone got any tips ?
My computer I´m testing with doesn´t get connected. Access tracker shows errorcod 201 "User not found"
But I managed to onboard a iphone. Problem is auth. source showes Active Directory instead of Onboard database.
Service has auth sources: onboard database, active directory, and a mac-list (in that order)
Very strange...
/Daniel
Contributor II
ok, so I managed to get my computer to work also by adding user name strip :/
But auth source in access tracker showes AD as source...
But if I revoke the cert i get denied. So is this how it should be by design ? I thought onboard database would show as source.
How does your access tracker look for onboarded devices ?
Am I missing something ?
/Daniel
The only authentication source that should be defined would be your identity store (Active Directory).
Contributor II
Ok, so devices are actually not authenticated against the onboard database. The certificate is the mechanism controlling the access for them ?
So should I need to strip /:user to actually make this work ? Can´t remember having this in there before and it has worked before.
/Daniel
All the certificate does it replace the user password. The user is still authorized against the identity store.
Contributor II
Great thanks, now I understand the proccess better.
/Daniel
