Contributor I
Onboarding clients using Cisco and HP switches
I have a requirement where i need to integrate CPPM with Aruba controller, cisco switches (2900) and HP switches for Onboarding. Integration with Aruba wireless solution has been completed, but I am having a hard time integrating with Cisco and HP switches. Pls help with any solution documents or step by step guide to achieve this.
thanks in advance.
Trusted Contributor I
Re: Onboarding clients using Cisco and HP switches
specifially onboarding? are you going to onboard wired users? what exactly is the scenario here?
looking at the basic requirements for that you have to be able to do captive portal redirect. something i don't expect on a cisco 2900 (EOL for ages), or is it a more recent model? for the HP it depends on the model / firmware.
Contributor I
thanks for your reply. Requirement is to onbaoard wired users. Cisco switch- 2960 ; HP switch- 5500.
first of all i personally always get a bit annoyed when i hear the requirement is ... without a good argument. but that is up to you to get in to with the customer.
it seems both the cisco 2960 and hp 5500 support L3 http redirection.
https://supportforums.cisco.com/discussion/11458526/not-working-central-web-authentication-switch-and-identity-service-engine
called portal in this HP document, it does mention: available only on the HP 5500 EI series.
http://h17007.www1.hp.com/device_help/H3C-Manuals/5500/5500-Configuration-Guide%28R2215%29.pdf
the general idea is you configure the switchport with dot1x and portal fallback. a non onboarded user will be redirected to the portal page on the CPPM and start the onboard proces there. during the proces you will probably  get a certificate to be able to do dot1x authentication after the onboarding proces.
this isn't the easiest of configs, it might be wise to look into working with your Aruba partner on this.
Contributor I
Onboarding successfully tested on Cisco 2960. Enclosed configs where used on cisco switch. Looking forward to test on HP switches now, but cannot find any relevant documents.
