Onboarding issues when using registration authority mode with SCEP to PKI
This thread has been viewed 19 times
  • 1.  Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Mar 31, 2017 11:48 AM
    when I configure Clearpass as a registration authority, I put in the SCEP URL and Challenge, then I fetch the CA cert and receive the chain as expected.
    When I go to the the device_provisionning php page on the client to onboard, I receive the following (regardless of device types)
    Unable to extract certificate from SCEP response (error:0D07207B:asn1 encoding routines:ASN1_get_object:header too long
    error:0D0D106E:asn1 encoding routines:B64_READ_ASN1:decode error
    error:0D0D40CB:asn1 encoding routines:SMIME_read_ASN1:asn1 parse error)
    From the PKI side the certs are issued and from Wireshark I see 200 accepts from the PKI :
    Thoughts on this ?
    Much appreciated,
  • 2.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Mar 31, 2017 11:50 AM
    What type of PKI environment are you proxying to?
  • 3.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Mar 31, 2017 11:52 AM
    Hi Tim,
    Windows 2008 R2 PKI.
  • 4.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Mar 31, 2017 11:55 AM
    We are also using the same exact SCEP URL and Challenger for an MDM and it's working fine.
  • 5.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Mar 21, 2018 07:52 AM
    Did you get this fixed? I have the same problem. I am using the SCEP in MobileIron and it works. When I use it in ClearPass I receive the same error as you.
    I have changed the settings on the PKI server like described in Step 4 - point 3 and 4 from the website:
    Configure and use SCEP certificates with Intune
  • 6.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Aug 16, 2018 04:19 AM
    I have the same problem too. Did anyone solve ?
    ClearPass 6.6 and Windows Server 2016
    > the following Error message in ClearPass GUI
  • 7.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Aug 16, 2018 09:27 AM
    We have not officially qualified ADCS 2016, but try adding mscep.dll to the end of the NDES URL.
    Ex: http://certsrv/mscep/mscep.dll
  • 8.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Aug 16, 2018 04:25 PM
    I found that this was caused by the HTTP proxy, when configured on ClearPass.
    In this case, I needed the proxy to retrieve updates, fingerprints etc and couldn't leave it blank but if I removed it, everything was working fine :)
    Cheers,
  • 9.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Aug 17, 2018 10:02 AM
    Tim and Overclock,
    Thank you for prompt reply.
    I already set the "http://172.31.xxx.xxx/certsrv/mscep/mscep.dll" for SCEP URL field.
    And I did not use the http proxy.
    I'll try to check the configuration of Windows Server again.
  • 10.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Aug 22, 2018 11:46 AM
    I set up ClearPass 6.7 in the same environment, same ADCS server.
    It worked fine. Unfortunately 6.6.5 still shows an error.
    Thank you for your adivices.
  • 11.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Sep 18, 2018 05:37 AM
    I am still trying to get this configuration done. When I configure the Certificate Authority as Registration Authority and I add the SCEP URL:
    https://pki/certsrv/mscep/mscep.dll
    I also have the option to add a SCEP Challenge Password. The SCEP Challenge Password (as far as I know) can be obtained via the URL:
    http://pki/CertSrv/mscep_admin/
    I tried to add the CA with and without configuring a SCEP Challenge Password. Both options aren't working and I see the following error in the EventViewer on the Windows PKI server.
    Without SCEP Challenge Password:
    EventID 28 - The Network Device Enrollment Service cannot locate a required password in the certificate request. Either a password must be present in the certificate request or the certificate request should be signed with a valid signing certificate. The signing certificate must chain up to a trusted root in the Enterprise store. The signing certificate and the certificate request must have the same subject name or subject alternate name.
    With SCEP Challenge Password:
    EventID 29 - The password in the certificate request cannot be verified. It may have been used already. Obtain a new password to submit with this request.
    I guess I have to troubleshoot the Windows PKI server instead of ClearPass.........
  • 12.  RE: Onboarding issues when using registration authority mode with SCEP to PKI
    Posted Sep 18, 2018 06:17 AM
    I got it working by following the procedure in the blog post, but I am not sure what the impact is on the Windows PKI environment......
    https://www.petenetlive.com/KB/Article/0000947#PWDOFF
    Parts:
    • NDES Disable Password Requirement.
    • NDES More Password Options and Renewing Certificates
