I have configured onboard service and all is well teh issue is quick connect stuck in Checking connectivty and keep tring to connect to the Secure SSID and when I check access track I found that it Say EAp method not support by client and it is support by the Device and attached the Access tracker
Samsung Note-2 android Kitkat
There are know issues with the 802.1X supplicant on the Note 2. You may want to stick with PEAP.
Dear Tim thank you so much I tried with Samsung S4 worked like charm no problem at all :) thank you Expert :)
