Onconnect for Wireless Enviroment?
Hi community, I was wondering if Clearpass Onconnect feature can be used in Wireless enviroment, cause I have some wireless printers that does not support 802.1x protocol.
Thank you.
Re: Onconnect for Wireless Enviroment?
No. OnConnect is for wired networks.
Use MAC authentication for headless devices. MAC authentication is also recommended on the wired network over OnConnect.
Tim Cappalli | Aruba Security
Thanks Tim, I'll try with MAC Auth.
