Super Contributor II
Onguard deployment guide
HI All,
I'm in the middle of trying to setup an Onguard deployment for a customer however despite the bits and pieces in the Clearpass deployment guide i can't find any really comprehensive guide to deployment or the options / capabilities of the client.
Does anybody know of any resource that you may be able to share that could assist with planning / deploying onguard?
Scott
Re: Onguard deployment guide
so after speaking with the local SE's and the TAC, i have found out that no such document exists.
looks like its going to be lots of lab time this week!
Can someone from Aruba please take not that this is a bit missing piece of the Clearpass documentation set and would be of great benefit!
Scott
Scott,
The OnGuard guide is currently being worked on. It is a high priority document for the clearpass team. I will post a notice when it is completed.
Thank You,
Troy
Hi Troy,
Thanks for the update.
Is there a draft version available at all for partners?
Scott
Sorry nothing yet I will let you know :(
Thank You,
Troy
I was just searching for similar documentation, any releases yet?
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Sorry nothing yet. I will keep everyone posted
Thank You,
Troy
MVP
This realy is one document we all need, so we'll just keep bugging you untill we get our guide you know :smileywink:
Koen (ACMX #351 | ACDX #547 | ACCP)
It is done and currently being reviewed, so I hope we will release it soon. :)
Thank You,
Troy
MVP
Outstanding.
Looking forward to this.
Have yet to get a chance to test Onguard but it is on the list!
