Onguard on onboarding WLAN
I am doing POC @ one of client for OnBoard & OnGuard, customer want to apply onguarding on BYOD device which use dual SSID onboarding Please confirm whether it is possible to apply heathcheck on onboarded client & assing proper role. I have configured DUAL SSID onboarding properly, but unable to understand where to apply posture enforment policy where client will be assinged quarantine & full access role after health check.
Kindly share if any document available for onboard+onguard configuration.
Re: Onguard on onboarding WLAN
Yes, you can. This would be exactly like a standard OnGuard deployment. You would combine your posture rules with your user and device rules in your enforcement.
Tim Cappalli | Aruba Security
Do you have any configuration example.
