Occasional Contributor I
Other wireless vendor(non-aruba) use ClearPass for self-register
Now my aruba controller use ClearPass for self-register it can work by i setting service by equal ssid "self-regis" on ClearPass refer aruba.jpg
But if other vendor(non-aruba) use ClearPass for self-register too. how can i setting service ? and if i setting service refer non-aruba.jpg is that right ?
thankyou.
Re: Other wireless vendor(non-aruba) use ClearPass for self-register
What vendor are you using ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
ruckus
If you import the Ruckus radius dictionary into Clearpass, then you can specify the Ruckus SSID just like Aruba.
You can download the Ruckus radius dictionary on the Ruckus support site: https://support.ruckuswireless.com/answers/000005579
I've attached a picture of what it should look like.
