G1J
Occasional Contributor I
Patch Management Grace period
Hi
is anyone using the grace period with the windows patch management posture checking? I have it configured to check Microsoft Windows AutomaticUpdates for security patches only, which identifies when machines have outstanding patches but it imediately quarantines the machine despite have a Grace Period of 3 weeks configured.
Am I missing something, I can't find any information on it.
Re: Patch Management Grace period
Here is the information that I found in the Help system in CPPM 6.5. Not sure if this helps, but it's a good place to start:
Zach Jennings
G1J
Thanks Zach
Looking at that I have everything set correctly and it should work, no sign of a grace period being applied though.
Nan
Hi G1J... Have you figured out the issue?
