Contributor II
Per-user customization of maximum allowed Onboarded devices
We are setting up Onboard for our users with a maximum number of allowed devices that a user can register. However, there are use cases in our company where some users who do testing with many different types of devices and may need to Onboard more than the normal maximum number of 2. How can we set it up so that some users or groups of users are allowed to Onboard more than 2?
Tim Haynie, ACMX #508, ACDX #384, ACCP, CWSP, CWAP, CWDP, CCNP R/S, CCNP Wireless, CCNA Security, CCDA
Re: Per-user customization of maximum allowed Onboarded devices
Create a new Application enforcement profile with the number of devices like below:
Then in your Onboard Authorization service, map the AD group to the new enforcement policy either directly or using TIPS role mapping.
Tim Cappalli | Aruba Security
Contributor II
What about the "Maximum Devices" field found under the provisioning settings in the Onboard configuration? Should this still be set to 2, or does it need to be set to 0 (ininite) and make another enforcement profile in Policy Manager that sets all other users to 2?
That value will apply for any authorization response that does not contain the Max Devices attribute.
