Regular Contributor I
Phone number validation
To check the guest's phone numbers, I use the validator "NwaSmsIsValidPhoneNumber". It works fine but now I need to force guests to add a + before the number. Like +044234657890
How can I do this ?
Dimitri
MVP
Re: Phone number validation
Change the Validator to IsRegExMatch and use this regex:
^\+(?:[0-9] ?){6,14}[0-9]$
That should enforce the E.164 standard.
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Thanks, I will try it.
Dimitri
A fast feedback, working fine thanks.
Dimitri
I need a new regex that checks that there are only numbers with no spaces and max lenght is 15 digits. Anyone can help me, thanks.
Regards
Dimitri
MVP
Many regex testers and libraries out there mate. [0-9]{15} is the simple answer.
Regards
John Solberg
Ok thanks, it's allright.
Try using /^\d\d\d-\d\d\d-\d\d\d\d$/ You just need to remove the - if you don't want the standard US format
Thank You,
Troy
Thank You,
Troy
