Occasional Contributor I
Possible to OnBoard RHEL/CentOS?
I read that it is possible to use EAP-TLS / OnBoard with Ubuntu. But is it also possible to use EAP-TLS / OnBoard with RHEL/CentOS?
Note, we don't necessarily need to do anything with OnGuard/Posturing.
Thanks --
Re: Possible to OnBoard RHEL/CentOS?
Yes, you can use the Web-Based Provisioning feature in Onboard for devices that can't support automated provisioning.
Tim Cappalli | Aruba Security
@timcappalli | | ACMX #367 / ACCX #480
