Regular Contributor I
Posture Checking with EAP-TLS
Hello Everyone,
I would like to perform posture checking on my wireless clients who are authenticating with EAP-TLS, however in windows i cannot find a way to enable the NAP agent on the EAP-TLS configured wireless network.
From looking online i found that you need to enable Enable Quarantine checks but the instructions only refer to EAP-PEAP:
To view PEAP properties of a network connection for wireless 802.1X-authenticated computers, right-click the wireless network connection, click Status, click Wireless Properties, click the Security tab, and under Choose a network authentication method, next to Microsoft Protected EAP (PEAP), click Settings.
Is it currently possible to do health checking via clearpass and NAP agents for clients connecting via EAP-TLS?
-ELiasz
ACDX, ACCP, CISSP, CWNA
Re: Posture Checking with EAP-TLS
Posted too soon.
I had to enabled the EAP Quarantine Enforcement Client on the device under NAPCLCFG.MSC
Also i configured the wireless profiles with EAP-PEAP outer method, and EAP-TLS as the inner method(to still allow for certificate authentication). This allows the NAP Check to be performed since it requires EAP-PEAP.
Hope this helps anyone who may come across this,
-ELiasz
