Contributor II
Power Cut
One of the Clearpass Cluster nodes suffered a power cut this morning.
It came back up and back in sync, but I have seen this error a few times afterwards:
2017-10-23 14:19:55+01:00 CPPM[clp01] profiler: Profiler ip:192.168.70.8 unstable
This is from both nodes - is this part of the resync or is it a problem?
Re: Power Cut
I've experienced a similar issue after upgrades with an error that says "Battery Sync Unstable". Working with TAC they can stop/start this service or process and it should stabilize. I would start there.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Contributor II
Re: Power Cut
HI
Thanks for the reply, yes it is back to normal now :)
