Problem: Guest available to access CPPM over CN certificate
Hello folks.
I have a a captive portal over CPPM and a SSL certificate in order to get a HTTPS portal. The dhcp scoop is manage by the controller and it is nat to a costumer firewall for internet.
The problem is that the users connected in SSID guest (captive portal) are available to get CPPM page over the CN.
SSL certificate: CN: example.company.com
Name of server: CPPM
Dns of CPPM: internal
Scoop guest: over controller
Dns: google
Captive portal page: example.company.com/guest/registre.php
If the guest put on the browser : example.company.com after get access to internet is avaible to access CPPM
How I can fix this big hole of security?
Hopping yo can help me.
Best regarda.
Re: Problem: Guest available to access CPPM over CN certificate
Use the application ACLs under the server's configuration section.
Tim Cappalli | Aruba Security
It´s not working! is this acl aplication works only with the IP management? or works on the data IP too?
