Problem about Using SHA-1 in API XML
Hi All,
I want to use API XML in my External Portal XML Server.
It's right when I send secret in "cleartext" with API xml command, the results are as follows:
However, it's invalid code when I send secret in "SHA-1" or "MD5" with API xml command, the results are as follows:
I have found a lot of information, but I don't find a solution.
who can tell me the reasons? Any suggestions are great appreciated.
fyper
