Super Contributor I
Problem with Licensing
Hi, i have ClearPass Policy Manager 6.2.
I observe daily the same value in the option Licensing. No changes.
I need help me
Re: Problem with Licensing
It updated at 3 am this morning according to your screenshot.
Are you saying that these values are exactly the same everyday?
Tim Cappalli | Aruba Security
Super Contributor I
Yes
Please open a TAC case
Thank You,
Troy
Super Contributor I
Ok.
Thanks you
