Problem with authentication Onboard
Hello. I have one problem.
when I login with a AD user, example EDUARDO, I can create the certificate profile without any trouble. If I login with a user _edu or e.paredes I get this message(see the attach)
Thanks.
Re: Problem with authentication Onboard
Only one field in Ldap is looked at for the Valid username.  If you want users to put in an email address,  what you can do in the service is to strip the .edu part of the username:
