MVP
Problems with MDPS - any updated complete tech docs yet?
My scenario is "simple" - atleast in terms of the advertised BYOD.
Give users with iPads the option to go through the MDPS procedure with Amigopod.
There will then be a second encrypted SSID using EAP/TLS the guests connect to afterwards.
We've followed the beta MDAC guide from may 2011, but it's not working. When connecting the iPads just keep prompting for "Password" and no input works - neither the correct password nor the username (which I saw mentioned somewhere should be enough). The installation of certs on the iPad looks correct according to the guide, as well as the certs I've installed on both the Amigopod and Controller. Amigopod is working as Root CA.
I opened a TAC case on the issue a few days ago, but with no response so I'm trying the trusted community before I start nagging. I notice from various posts I'm not alone on working our way to a MDPS installation. There are several that have similar question and either no solution or they are routed to TAC, and no explanation solves the post..
Would it not be possible to get an updated document explaining the updated procedures for MDPS? I've seen hints about it for a couple months here now (cam?). There are alot of various posts regarding MDPS issues as far as I can tell, but none of them gives a solution to the whole procedure - including certificates for the Amigopod web server which have many posts here.
I also see a post from cjoseph explaining something in the way of not needing to upload certs on the controller when using Radius which I'm thinking have something to do with a new way to implement MDPS also?
cjoseph wrote:
Great news!
You don't have to import any certificates on the controller for EAP-TLS to work.  The radius server only needs a remote access policy that has "Smartcard or other Certificate" and the client only needs a client certificate issued by the same CA.
John
Regards
John Solberg
-ACMX #316 :: ACCX #902 :: ACSA
Aruba Partner Ambassador
Intelecom/NetNordic - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Re: Problems with MDPS - any updated complete tech docs yet?
My statement above was only made in response to a specific question about setting up  a controller with a radius server using TLS.  It was not made with MPDS in mind and it should not be taken that way.
There are quite a few more things that the MDPS solution provides such as certificate distribution without IT Intervention, Certificate Revocation checking, integration of asset information and user information into the certificate, etc that is beyond a vanilla TLS deployment.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
MVP
Thanks cjoseph, that clears that up.
Still I'm unable to get this darn thing to work, and the changes in the Amigopod GUI for this tells me there atleast have been changes to the procedure.
Unable to get pass the issue where iPad asks for Password when connecting to the SSID.
I've followed the guide to the letter. I can't trace the client traffic since it's basically not showing up on either controller or amigopod when connecting to the TLS ssid.
Regards
John Solberg
Moderator
Let me try to give you some pointers on what could be causing the issue. If I understand your description correctly, you have successfully provisioned one of your test iPads and when you attempt to connect the TLS SSID you are getting prompted for a single password.
This is typical of a couple of scenarios that might be worth checking:
  • time synchronization between the Amigopod signing the client certificates and the EAP termination point. I am assuming at this point you have the EAP-TLS terminated on the Aruba controller
  • OCSP revocation check has failed. Again with EAP-TLS termination on the controller it is worth confirming that the OCSP revocation checkpoint is configured correctly and pointing to the correct OCSP responder URL on Amigopod. This is an example of the default URL published on Amigopod.
http://<Amigopod IP Address>/mdps_ocsp.php/1
Just to clarify the previous point about installed server certificates on the controller. This is only required when you wish to terminate the EAP-TLS on the Aruba controller itself. If you are intending on terminating the EAP-TLS on an external RADIUS then there will be no need to import and manage the certificates on the controller. The server certificate would be installed on the RADIUS server instead in this case.
In the more recent versions of Amigopod you can certainly opt to terminate the EAP-TLS transactions of your MDPS deployment locally on the internal RADIUS server. There is some discussion around this support and other changes to MDPS in the last couple of release notes associated with the 3.5 and 3.7 releases of Amigopod.
Hope this helps and I would be happy to follow up on your TAC case if you can 'pm' the case id.
Rgds
Cam.
MVP
Hi Cam,
thanks for the followup!
Case # 1277830 - since no pm is available here ;)
Yes - I've set the TLS-Termination to happen on the Controller, as per the guide.
The time sync is OK.
I've set OCSP in Provisioning Profile to the same as you pasted - with the correct IP.
I have installed a trusted SSL certiticate on the Amigopod server for the intent of using it for https on the guest portal self-registration, and just using Amigopod as Root CA for this MDPS part.
John
Regards
John Solberg
MVP
In regards of the OCSP - I see that there is an option on the Controller to make it a OCSP client. I haven't done anything with that for this installation. Correct?
John
Regards
John Solberg
Moderator
John,
I am not sure I follow your comment below.
'I've set OCSP in Provisioning Profile to the same as you pasted - with the correct IP.'
The only place OCSP would need to be configured in your deployment would be on the controller (or generally on the EAP Termination point).
I am sure the TAC would have requested this already but one of the more interesting debugs to run on the controller would be a show auth trace-buf whilst the iPad is trying to connect via TLS.
Rgds
Cam
MVP
Still no response from TAC on the supportcase from thursday. Been doing auth trace-buf without that seeming to tell me anything. This should be in the debug logs I've sent tho.
OCSP..
Well - the provisioning profile in MDPS on Amigopod has an option to add an OCSP url to the client certificate. I started without, then tried with it on - to the URL that is similar to the one you posted.
For setup of OCSP on the Controller.. I see this described on page 325-327 in the 6.1UG. What I don't see is how I'm supposed to create the OCSP responder certificate on Amigopod - as this is the Root CA. Any hints? :) I do have a certificate called the same as the root cert only added (signing) - might this be it?
John
Regards
John Solberg
MVP
From the auth trace-buf
Feb 6 20:55:39 station-up * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 - - wpa2 aes
Feb 6 20:55:39 station-term-start * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 95 -
Feb 6 20:55:39 station-term-end * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68/akme_TLS 7608 - failure
Feb 6 20:55:43 station-up * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 - - wpa2 aes
Feb 6 20:55:43 station-term-start * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 95 -
Feb 6 20:55:44 station-term-end * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68/akme_TLS 7608 - failure
Feb 6 20:55:45 station-up * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 - - wpa2 aes
Feb 6 20:55:45 station-term-start * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 95 -
Feb 6 20:55:46 station-term-end * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68/akme_TLS 7608 - failure
Feb 6 20:55:58 station-up * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 - - wpa2 aes
Feb 6 20:55:58 station-term-start * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68 95 -
Feb 6 20:55:59 station-term-end * 34:51:c9:ab:a8:06 d8:c7:c8:25:a7:68/akme_TLS 7608 - failure
John
Regards
John Solberg
Moderator
Hi John,
That is interesting looking at your trace. It appears that the client is never attempting to exchange it client certificate. If you have a look at this successful auth-tracebuf below you will see what is expected next in the transaction.
(Aruba6xx) #(Aruba6xx) #show auth-tracebuf count 20
Auth Trace Buffer
Jun 21 16:50:19  station-up             *  e8:06:88:9c:a3:50  00:24:6c:34:bd:8a                      -    -    open system
Jun 21 16:50:19  station-data-ready     *  e8:06:88:9c:a3:50  00:00:00:00:00:00                      1    -
Jun 21 16:51:16  station-up             *  e8:06:88:9c:a3:50  00:24:6c:34:bd:8a                      -    -    open system
Jun 21 16:51:16  station-data-ready     *  e8:06:88:9c:a3:50  00:00:00:00:00:00                      1    -
Jun 21 16:51:40  station-down           *  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    -
Jun 21 16:51:45  station-up             *  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    -    wpa2 aes
Jun 21 16:51:45  station-term-start     *  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      1    -
Jun 21 16:51:46  client-cert           ->  5c:59:48:aa:59:e8  00:24:6c:34:bd:80/corp-employee-dot1x  915  915
Jun 21 16:51:46  client-finish         ->  5c:59:48:aa:59:e8  00:24:6c:34:bd:80/corp-employee-dot1x  -    -
Jun 21 16:51:46  server-finish         <-  5c:59:48:aa:59:e8  00:24:6c:34:bd:80/corp-employee-dot1x  -    -
Jun 21 16:51:46  server-finish-ack     ->  5c:59:48:aa:59:e8  00:24:6c:34:bd:80/corp-employee-dot1x  -    -
Jun 21 16:51:46  eap-success           <-  5c:59:48:aa:59:e8  00:24:6c:34:bd:80/corp-employee-dot1x  -    -
Jun 21 16:51:46  station-data-ready     *  5c:59:48:aa:59:e8  00:00:00:00:00:00                      1    -
Jun 21 16:51:46  wpa2-key1             <-  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    117
Jun 21 16:51:47  wpa2-key1             <-  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    117
Jun 21 16:51:47  wpa2-key2             ->  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    117
Jun 21 16:51:47  wpa2-key3             <-  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    151
Jun 21 16:51:47  wpa2-key4             ->  5c:59:48:aa:59:e8  00:24:6c:34:bd:80                      -    95
Jun 21 16:52:22  station-up             *  e8:06:88:9c:a3:50  00:24:6c:34:bd:8a                      -    -    open system
Jun 21 16:52:22  station-data-ready     *  e8:06:88:9c:a3:50  00:00:00:00:00:00                      1    -
(Aruba6xx) #
This can sometimes indicate that the client is not happy with the client certificate for some reason and therfore wont initiate the certificate exchange. I will follow up on the support case and see what else I can find out.
Rgds
Cam.
