Moderator
Profiling with Cisco WLC
Hi
I'm integrating a CPPM v6.0 and a Cisco WLC in one customer of ours and am having some trouble with the endpoint profiling.
I know we should relay DHCP traffic to the CPPM in order to profile endpoints. However, due to some limitations in our customer's network, we will probably have to rely exclusively on SNMP queries from CPPM to WLC. Is that even possible?
If so, I think I've configured it correctly (I've configured the device as Airespace) but I can't find any command to check if the SNMP/SSH query is reaching the controller and what information is being obtained from it. Do any of you guys know how to do this?
Thanks a lot
Regards
Samuel
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Re: Profiling with Cisco WLC
Unfortunately, SNMP only works if devices are configured with an SNMP read string.
What kind of network is this, enterprise encrypted?
Colin Joseph
Aruba Customer Engineering
Moderator
I've done that, my CPPM is supposed to be checking ARP tables and so on from my controller. Unfortunately, dev profiling isn't yet working.
regards
Samuel Pérez
Moderator
I'm still having trouble with it :(
I've done the following:
  • SNMP read enabled towards Cisco WLC management IP address
  • DHCP relayed from Cisco WLC towards CPPM
  • Subnet scan configured for the WLAN-Employee subnet
Sadly, when I go to "Endpoint profiler", I still get "ClearPass Profile has not received any endpoint information"
Any idea?
Samuel Pérez
Moderator
It's up and running :)
Samuel Pérez
Trusted Contributor I
could you explain what you did to make it working? might be useful for other people in this situation.
Curious as well to know what you did to get it working.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Moderator
Hum, sorry for the delay.
I didn't do anything special, just double checked my config and corrected some silly mistakes.
summarising:
  • dhcp relay sent to the CPPM
  • CPPM snmp-checking the controller
worked like magic :)
Samuel Pérez
Aruba
I know this post is dated, but i am having the same exact problem.  I enabled SNMP Read, DHCP forwarding to CPPM, and subnet scan; yet there is 0 entries discovered.
When you got it to work, you said you double checked your settings; were there mistakes, or did it just start working?
thank you
AMFX | ACCX | ACDX | ACMX
Clembo,
What is doing the forwarding, the WLC? Is that WLC also doing DHCP? If that is the case it will not forward.
If it is an external dhcp server, we need to make sure those packets can truly get to the CPPM.
Colin Joseph
