Contributor I
Protect from connecting switch to the network
Hi guys,
Basic configuration deployed at our network for an endpoints is DOT.1x and Mac-Authentication. If i want to protect from connecting rouge switches, How should i do that ? Using 802.1x, Mac, Other method?
We have only Comware5, Comware7 Switches with Cisco small router (1920) at our branches.
Thank you.
Contributor I
Re: Protect from connecting switch to the network
Anyone ?
Well, not a single bit of traffic will pass to the connected switch as long as it isn't authenticated. Rogue switches shouldn't be able to authenticate to your ports.
ACMP, ACCP, BCNE
for my case, i connected a small hub (8 ports), the hub connected to my switch with 802.1x+ MAC auth.
the 1st user connect to the hub will get mac auth through the hub, but the next one authenticate will make the 1st user disconnected
